7 members (1955 1 Series, Bill Hanlon, Otto Skorzeny, rfs56trk, DHedrick, Robert Crandall, klhansen),
123
3
Mod | | | Forums66 Topics128,087 Posts1,056,399 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | You may not want it to be full. The original tank gas cap is not pressurized. Gas station tanks may be underground so the gas is at ground temperature. Here in the South, where temps usually hit 90 in the summer, that cool gas heats and expands a lot. On original trucks the cab heats up like a toaster oven in the sun and so does the gas in the tank behind the seat. Gas can force it's way past the gas cap seal and ruin a nice paintjob. Back in those days you had to remember not to "filler up".
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | |
