| | | Forums66 Topics128,264 Posts1,058,352 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,944 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,944 | What's the voltage at the battery posts after running a while? If it's over 7.5, the voltage regulator points are stuck (the coil behind the Field wire) or there'a a grounded spot sonewhere in the field wire between the generator and regulator. It's also possible the battery just has a low state of charge and the generator is trying to recharge it. That would require driving for several hours without running the starter. Charge the battery overnight or longer and see if the problem goes away. Jerry
