I just want to double check myself on lifting my 235 engine and installing it. At the front, I feel pretty confident. I have a short chain attached at both ends to the two 3/8 bolts that attach the thermostat housing to the head. At the rear, I have a 3/8 forged eye bolt installed in place of the rear bolt that holds the rocker arm assembly in place. Thanks for your help.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
