0 members (),
146
2
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14454 04/22/2004 8:55 PM | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Does the engine have a tendency to start just as the key is released from the "start" position sometimes? if so, you may not be getting full voltage to the coil during cranking. Check the voltage at the coil "+" terminal during cranking. It should be 9.5 volts, minimum. A bad ignition switch contact, or not having an ignition bypass lead from the starter solenoid to the coil could be starving the coil for voltage during cranking. Jerry
