dgrinnen Be sure your gauge connection is oil tight,a leak under the dash creates a tremendous mess you can't get to to clean it up . Also I think on the gauge you'll need a nut with the ferrel made on it. Been a while since I fought that,hopefully when you took one loose it wouldn't be too far gone to re-use. Back in the day you usually had new nuts available,now the kid will just look at you !!
