| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Don't those wire-wound strings do a good job of reaming out precision-drilled holes to the wrong size? Use whatever solvent floats your boat to soften the deposits, but use only high pressure air to blow the passages clean. An instructor at the GM training center in Memphis used to say "Put 55 gallons of air through every passage!" Jerry
