Check to see if you have continuity from the coil tower to the - side of the coil. If you don't, it indicates a bad secondary winding in the coil. It's unlikely that you have 2 bad ones, but it is possible. The fact that the points are sparking indicates that you have a good primary winding in the coil. What do you mean when you say you have 6 volts at the negative side of the coil? How exactly were you checking that?
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem |
