1 members (SlimSix),
129
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,482 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,482 | You're right. That is the early one. The later one was based on the Pontiac 389. I can't remember if it had dished pistons, but I don't think so. I also think the bore and stroke on the 2 may have been different. But I could be wrong on that. Haven't had one of those apart since around 1972. All the later ones had a problem with oil leaks where the oil filter mount attached to the block. I remember that very well. Wasn't easy to fix, either.
