Quote
Originally posted by Tony:
You guys driving easy and getting 10 MPG should look at your carbs. Old Rochester B's have been know to the power valve jet open at low speeds.It usually won't have black smoke rolling out, but rich enough to kill the fuel mileage.Our 45 2 ton with a 235 gets around 11-12 mpg, and it heavier and lower geared than a pick up.
Thanks Tony,
That sounds like a good suggestion.
Then you will know the truth, and the truth will set you free.
- Jesus -
