Originally posted by chevyb:
Dave,
1931 Chevys had up draft carbs., that is why the throttle linkage is missing.
31 trucks have downdraft carb. I checked casting bumber on intake to be sure. Is the crank pivot attached to the frame? (motor is bolted to frame without mounts)
The tires are almost flat, so the GVW is ~ 1/12 ton. When I get tires fixed I hope I can type better too!
