| | | Forums66 Topics128,180 Posts1,057,156 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | OK- - - -the 54 flywheel should have the same number of ring gear teeth as the 216. (139) Chevy didn't change to a 12 volt starter and a 168 tooth flywheel gear until mid-year 55. The bellhousing, clutch, and other parts will be a direct swap. Other than the rear housing, and possibly the output shaft, the transmissions should be the same. The SM-319 overdrive trans is essentially the same as both of your others internally, except for one extra hole in the main case. The Borg-Warner planetary overdrive bolts onto the back of the Chevy case. Your Nova rear axle might work, but it's likely to have a higher speed gear ratio than would be appropriate for an OD trans. An OD in an early pickup works best with a 3.50:1 or lower gear ratio. The Nova will most likely be a 3.08 or so, and you'd only be able to run OD on flat land or downhill. Jerry
