Is the corn head grease no longer a preferred solution?
Probably fine to use. The Lubrication recommendations in the service manual are pretty wide open. So lots of options.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
