0 members (),
94
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | Do you have a 1/2" drill motor or a drill press? Wrap masking tape around a 1/2" bolt until the bushing is a snug slip fit, then tighten a nut onto the bolt so you can spin it in the drill. Use emery cloth or sandpaper to dress the OD until it's a couple of thousandths bigger than the crankshaft counterbore and tap it in with a little red or green loctite on the OD. Jerry
