Tiny, my generator has a stepped down housing with no band around where the brushes are. It's different from what's shown in the service manual, so must be an aftermarket or later model generator. That may be what your synapse is trying to tell you.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
