The Blazer one should work. I used the pedal from a '71 GMC pickup. (push with foot to set - pull to release)
I mounted it between the dash and firewall. It was just the right length to fit. Requires drilling holes in the firewall for the mounting bolts and the cable. Also drill hole in underside of dash for front bolt.
When installed, the pedal is higher than stock, so you have to lift your leg up more than I would prefer in order to set the brake. Other than that, it works OK.
https://www.lmctruck.com/1967-72-chevy-gmc/brakes/cb-1967-72-parking-brake-cables
