They don't go thru the inner fender. They go from the terminal block around the inner fender between it and the radiator support. Here's a couple pics from my '51. This is the right side, and the left side is similar. The parking light wire is the rearmost one on the terminal block that goes under the wires to the headlight thru the inner fender.
Kevin
1951 Chevy 3100 work truck
Photos
