| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2021 Posts: 11 'Bolter | | 'Bolter Joined: Jun 2021 Posts: 11 | Need some help in figuring out my Bellcrank set up. My original 1938 1-1/2 ton 216 was pulled and I installed a 1950 216. It seems that the return springs are hooked differently on the newer engine. I only have the 38 216 bellcrank to put on the newer 216. Will I need a later bellcrank set up to work with my pedals and linkage ? Thanks guys. Also will a 38 pick up radiator work in my 38 1-1/2 ton. Thank you. | | |
