I THINK the double bend end of the rod goes on the lever on the motor, then the other end with the grommet snaps into the control lever. I can't look because my parts are out in the deep freeze storage.
Or maybe it's the other way around. You have a 50/50 chance of the first option being correct. But you'll likely find that the first way you try is wrong. Murphy's Law, Right?
