| | | Forums66 Topics128,162 Posts1,057,049 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Thanks for your reply. I already have the gaskets. Are you saying you would forget them and use silicone instead? Removing the drums was a true nightmare with no adhesive sealing them to the hubs. The root of my questions are does anyone believe the addition of gaskets would create any problems. (Adding them will result in a slightly different contact location at the pumpkin ends of the axles).
Mike Barnes 1950 GMC 1-ton pickup
