| | | Forums66 Topics128,282 Posts1,058,496 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14286 11/06/2003 10:29 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | That's not quite true, you need to follow the markings on the filter housing. Mine has a pressure relief valve in the head of the housing that opens if the filter clogs. Running it backwards would not give a pressure relief and would not filter as well because the oil should flow from the outside to the inside of the filter element.
