I had that set up on a 50 3100 half ton. Someone had separated the front hubs and every so often the front lugs would snap off in a curve. I would keep a box of spares under the seat.
Did you replace the missing rivets? I would be more afraid of doing that job incorrectly than snapping a lug stud on a turn.
