| | | Forums66 Topics128,268 Posts1,058,394 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#14271 10/28/2003 8:14 PM | Joined: Jul 2000 Posts: 53 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 53 | I have a '62 235 with hydraulic lifters and a dual Offy/Fenton setup. I noticed that I was getting poor gas mileage, so I did some investigating. I figured that I was running rich since I spewed carbon out of one of the tailpipes when I gunned the engine. I pulled plugs and noticed that they were all covered in carbon, and the back 3 were wet. (The tailpipe that was spewing the carbon was attached to the front 3 cylinders.)
I adjusted the valves to ensure that they had 1 turn after the tapping stopped, and I adjusted the carb to a leaner mix. I took it for a drive, and it was running great. After about 60 miles, I decided to pull plugs again to check them out. They were still covered in carbon, and the back 3 were still wet.
I then checked the compression in one of the back 3 cylinders and one of the front 3. The back cylinder was reading about 75 lbs and the front was reading about 90 lbs. Both way too low. I only had time to fiddle with the front cylinder valves, backing them off 1/4 turn, checking compression, backing off another 1/4 turn, checking again. The compression improved, but not significantly. (The engine was cold by this time)
Now this is a recently rebuilt engine, so I wouldn't guess poor rings. Could the carbon be causing the valves to be unable to close all the way? Should I spray B-12 into the cylinders to clean up the carbon? What else can I try? How did all this sawdust get under the hood? | | | |
Entire Thread
Bad mileage, carbon, and poor compression
| tree91 | 10/28/2003 8:14 PM |
Re: Bad mileage, carbon, and poor compression
| Tony M | 10/28/2003 9:04 PM |
| tree91 | 10/28/2003 9:25 PM |
| 4ontheFloor | 10/28/2003 10:38 PM |
| tree91 | 10/28/2003 10:50 PM |
| ftyler | 10/28/2003 11:15 PM |
| 4ontheFloor | 10/29/2003 1:14 AM |
| warren | 10/29/2003 5:03 AM |
| tree91 | 10/29/2003 8:14 PM | |
