I would also suggest measuring the length and other dimensions of the engine and drive train to confirm what will and will not line up. The length of the 235 and what you have now will probably be different. The length of the water pump is a routine issue to be dealt with, as are the locations of motor mounts..
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
