| | | Forums66 Topics128,268 Posts1,058,393 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Yup, check for the "oil" to be way high on the dipstick. Sometimes a bad fuel pump will pump gas into the crankcase. And some 235s can be turned by the blades. Its not really a scientific test. If compression is above 100 psi or so in all cylinders, give the truck a tune up and enjoy it running.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
