1 members (Pre '68 Dave),
60
3
Mod | | | Forums66 Topics128,187 Posts1,057,312 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You can measure it if you want real numbers for that particular horn trumpet. May be 2X the draw of a 6V. But that's OK because the internal wires are 6V big and the diaphragm is metal, so not much can happen unless horn button sticks. If you are worried, run it thru a ballast resistor and add a fuse.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
