| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Cheap and easy. Won't gain a lot but it costs nothing. If you're timed to stock specs, those specs were set for about 65 octane gas. Leave your timing light in the drawer. Warm your truck up then time to fastest/smoothest idle and lock it down. Re set your idle then take it for a spin. If it doesn't ping under load or drag the starter you're good to go. You should be able to advance your timing at least 10 degrees. It made a noticeable difference in my 38.
