0 members (),
67
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | I'm a novice so grain of salt. The throttle shaft usually wears in the idle to partly open position. Wide open throttle, less wear. I remove return spring and linkage and try to move the shaft up and down by hand. A little bit of movement is tolerable.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | |
