8 members (TUTS 59, Wickedbass, moparguy, SWEET, walter74, 50Chevy3100, FAST55, 1 invisible),
103
3
Mod | | | Forums66 Topics128,065 Posts1,055,870 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | I have Camaro master cyl, combination valve*, front discs and rear drums. The master cyl and booster are tucked up as high as they can go under the floor of the cab so they are higher than the brakes.
The brakes have worked really well for about 1000 miles at this point. Day before yesterday, they were good. Yesterday, they were non-existent.
*combination valve has proportioning valve, metering valve, brake warning light switch built in.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
