7 members (Hanks custodian, 2-Ton, TUTS 59, Otto Skorzeny, festerhairball, HandyAndy, dt235sd),
83
2
Mod | | | Forums66 Topics128,060 Posts1,055,836 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | Truck has power brakes with booster and dual master cyl under the floor. My conclusion is that master cyl has to be replaced. Reasonable conclusion or did I miss something? Do you have residual pressure valves in the ports of the master cylinder? If you're running discs up front, they need a 2# valve, and drum brakes need a 10# residual pressure. If the master cylinder is below the level of the brakes, the residual valves keep enough pressure in the cylinders that air can't creep in and put a bubble in the lines. Even a tiny air bubble will cause the symptoms you're having. Jerry
