| | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | You ought to have enough room on the front end if you put it on stands and turn the wheels. On the rear, I'd disconnect at the differential union and check there. As long as your tubing is in good nick, you should be fine doing that and most of the brake pressure gauge kits include adapters for that union fitting.
