Both. I used a rear anti-roll bar from a 99 Accord, about 5/8 diameter, and it fits well. Mounted it on top of the frame just forward of the axle area and fabricated brackets to connect to the axle at the spring U-bolts area. The front bar is 7/8 diameter and came with the front sub-frame I used. The truck is very stable.
Mark
