| | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Have you tried soap? I remember putting a driveshaft carrier bearing in. Instructions said to use soap as a lube. First tried dish soap(detergent), didn't work at all. Engine oil didn't work. Worked up a thick lather from a bar of bath soap and it went in easily.
Harold Wilson 41 Chevy 3/4 Ton
