1 members (78buckshot),
106
3
Mod | | | Forums66 Topics128,187 Posts1,057,212 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | It's a shade tree fix, but I've used some painter's stir sticks or sections cut from a wooden yardstick to insulate a battery hold down from cable terminals that come too close to the metal framework. There are also plastic hold-downs available that completely protect against shorts at the cable terminals. A battery that completely fills the tray will have somewhat more cold cranking amperage available, so I'd recommend using the biggest battery you can and doing whatever is needed to prevent a short circuit. A thin piece of wood glued or riveted to the top of the hold-down frame under the terminals would be the simplest, least expensive fix.
The original 6 volt battery was a "Group 1" size. It was almost square, and it just barely fit through the hole in the floorboard. Jerry
