| | | Forums66 Topics128,193 Posts1,057,249 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 1,660 Curmudgeon | | Curmudgeon Joined: Mar 2010 Posts: 1,660 | Zero ohms = Empty ~ 30 ohms = Full ~13 to 16 ohms = 1/2
The tank level sensor has a metal stop for empty and full.
Remove the gauge wire on the tank. Ground that wire. The gauge must read empty. If not, do you have a 6 or 12 volt battery and if 12 volt, what voltage dropping device are you using?
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM." | | |
