2 members (Frank50, Joe H),
120
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,175 Posts1,057,056 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 182 'Bolter | | 'Bolter Joined: Jun 2016 Posts: 182 | Hello fellow bolters. There is too much play in my steering wheel. So I pulled out the shop manual and started to adjust it. Per the manual I pulled the pitman arm off the shaft. Next I loosened the the lash adjusting bolt 2 turns to remove load from worm bearings. Next I was supposed to gently turn the steering wheel till it engaged the gears. The problem is the steering wheel never engaged any gears. Wheel only stopped turning when it reached the 'stops'. No resistance except for the stops. What am I doing wrong? Thanks in advance for any help. Jon | | |
