Winter is Coming
I'm sorry you were not satisfied with the responses you got in your previous post. It sounds like no business is selling the pump you want. I would look for a used pump (evilbay, junkyard, swap meet). Send it to a professional rebuilding service.
"Adding CFM to a truck will only help at engine speeds you don't want to use." "I found there was nothing to gain beyond 400 CFM."
