I just bought a compressor pressure switch on Ebay after the elrctrical contacts in mine failed- - - -just make sure it's got the right setup of ports and the correct on/off pressure rating. They're not expensive, or complicated to install if you've got a little basic plumbing and electrical knowledge.
