| | | Forums66 Topics128,022 Posts1,055,360 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | That steering box is an aftermarket reproduction of the 84-87 Toyota steering box. It is sold by a variety of vendors and is also known as a 500 series. I have the original version of the Toyota box in my 56 which I installed in 2000. It has been trouble free. The box is close to the left rams horn manifold but clears ok. The later version moves the box closer inside the frame which may clear a big block. I have not seen one installed on a TF truck with a big block so I could only speculate as to the clearance. If you only have about 1" of clearance now it likely won't work. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
