| | | Forums66 Topics128,108 Posts1,056,239 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Yes, that's a good idea. Just be sure not to damage the input shaft snout with the drill motor chuck. It might be a good idea to wrap a couple of layers of tape around the end of the shaft, or maybe cut a slice out of a soda can to protect the shaft. It's hardened steel, but being careful is better than having to fix unnecessary damage. Even spinning the box in neutral will splash the solvent around effectively- - - -there's no real reason to engage any forward or reverse gears. Maybe use 4th. gear to get the output shaft and the rear bearing spinning. Jerry
