| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Good luck threading those bolts listed in the first link into a flywheel- - - - -they're for attaching an automatic transmission flex plate to the crankshaft. The ARP 3/8-16 X 3/4" or 1" flange bolts would probably work, WITHOUT a lock washer. Use blue LocTite instead. Jerry
