| | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,308 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,308 | Look for the short lower half panel in black primer. They are made correctly. You can see from the pictures online or in catalogs that they are. It seems that none of the full panels sold are bent anywhere near correct. If you need the full panel, cut the lower half off of the full panel and weld the correctly bent lower panel to it. This tip will add ten years to the end of your life. You will need to start taking better care of yourself because the last ten years of ones life are seldom pretty otherwise.
Entire Thread
inner cowl fitment, 1953 half ton
| Mike Burns | 05/26/2021 6:10 PM |
Re: inner cowl fitment, 1953 half ton
| klhansen | 05/26/2021 6:47 PM |
| Mike Burns | 05/26/2021 9:02 PM |
| 52Carl | 05/27/2021 3:03 AM |
| bluedot38 | 05/28/2021 10:25 PM |
| klhansen | 05/27/2021 3:11 AM |
| Achipmunk | 05/27/2021 1:49 PM |
| Mike Burns | 05/27/2021 4:18 PM |
| Mike Burns | 06/04/2021 8:19 PM |
| 52Carl | 06/05/2021 12:42 AM | |
