Originally Posted by Jon G
Hmm. The odometer is gear driven and so if it is working then we know the cable is turning and that tells us the transmission gear is probably ok. The speedometer needle relies on magnetism to make it spin, but if the needle jumps a bit when the rear bit is spun by hand that implies you do have magnetism. Make certain the needle isn't binding on the speedometer glass or somewhere on the dial. It won't take much to disable it even though the magnetic part is spinning...
Thanks!
I'm hoping to tear into it today to see if I can determine what the problem is.
1957 Chevy Panel Truck, powered by SBC 350 from 1977 Camaro
Author, Bring CHANGE Into Your Life (a truly easy investment tool)
https://www.amazon.com/Bring-CHANGE-Into-truly-investment/dp/1077276869
