7 members (walter74, Sjm, Jman, baldeagle, SmalltownTRKGuy, moparguy, 1 invisible),
343
Mod | | | Forums66 Topics128,166 Posts1,057,092 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2020 Posts: 431 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 431 | I see what you mean. I didn't notice that 121 was just a piece of wire. Anyway, you could splice into 39 but a splice has to be done correctly and isn't the best for your immediate question. Assuming the aftermarket volt meter has stud terminals with nuts, you would run 39 to it using a crimped-on ring tongue terminal. Then another piece of 39, with another ring tongue placed onto the same voltmeter stud, to Tach. A jumper, in other words. Avoiding a splice. Thank you! | | |
