Adapting the 4L60 to the GMC will eliminate the bellhousing motor mounts on the SM-420 setup. There will be no way to bolt the GMC/4L60 in without fabricating new mounts, at least at the engine/trans junction point, possibly altering the bellhousing crossmember for clearance for the transmission, and fabricating a rear crossmember to support the tail shaft housing of the 4L60. Plan ahead!
