Hy Justin726, welcome, it sounds to me like the master cylinder piston is not being allowed to return to its fully at rest position. Check the linkage under the truck to make sure there is some clearance in the linkage that must be taken up before the master cylinder piston actually moves. As others have suggested the flexible line from the frame to the rear axle brakes should also be replaced for age if no other reason. Hope that helps.
