| | | Forums66 Topics128,268 Posts1,058,375 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | Good Luck! A solution to your problem I've long wanted to try is; park the truck on a pretty good hill. Pull sparkplugs and pore several ozs of Coke in each cylinder. Then with the transmission in high gear walk away for a few days. When the truck is at the bottom of the hill you'll know the carbonic acid in the Coca-Cola has done it's job of dissolving the rust that had rust-welded the pistons to the cylinder walls.
RonR
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
