Good morning. I’ve installed a frame mount adapter and dual master cylinder on my 57 Chevy 3100. The parts came from CPP. I’ve replumbed the brake lines and bled the brakes. The only problem I’m still dealing with is if I install the pedal return spring in its original place, the M/C push rod is at an angle such that it doesn’t engage the bore correctly. There’s just one hole in the pedal arm for the pushrod so what can I do the fix this? I did read the tech article by Cletus which was very helpful.
Thank you,
Larry
