| | | Forums66 Topics128,187 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,876 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,876 | I make those axle flange gaskets from very soft aluminum sheet metal about .030" thick, using the dimensions of the hub and the bolt hole diameter and spacing as a pattern. They seem to work better and last longer than gasket paper, especially if the flange doesn't have tapered collets that keep the axle from shifting slightly forward and back on the studs. Jerry
