No. but looks like you may have wired it correctly only to discover you have some other issue. Plug open ports as said.
1. Check for 12V at coil pos with key on. Not cranking.
2. If 12V at coil, CHECK POINTS GAP. then take out a spark plug, keep wire attached, place threads only of spark plug on good bare metal ground. Key on, crank motor 5 sec minimum, watch for spark. Report
Does your coil say "Internally resisted" or "Externally resisted"?????????
Do you see gas squirting down carb when throttle is operated or did you try squirting some in there?
Trying to take this slow and careful rather than jumping all over the place with the 40 things that could be wrong.
One of THE most important things to start with in your case is history.
1. When is the last time you heard it run?
2. Has anyone taken out the distributor? or done work on it?
3. Has anyone done any work on the carb?
4. If yes to 2 or 3, was that before or after last time you heard it run?
