7 members (Gdads51, 55shaker, greenie-reddy, UtahYork, 3B, Peggy M, joe apple),
125
3
Mod | | | Forums66 Topics128,259 Posts1,058,291 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,940 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,940 | Either use a borescope to check for a scored cylinder, or pull the head and oil pan and remove the piston from the low compression cylinder. You're probably dealing with a ring that was broken during the installation process. Was the engine bored during the "rebuild", or did it just get a new set of rings? A badly tapered cylinder can cause rings to lose their tension and compression sealing ability very quickly. There's a procedure in the tech tips section for checking cylinder taper with a piston ring, a feeler gauge, and a little work with a calculator. If the taper is much over .005" the rings aren't going to last very long. Jerry
